Sensitivity.
MavicKhan
Cascais, Portugal
I've reduced my "yaw movement limit" to 50, as mostly recommended and am happy with it.
What settings are you using for the other 2 "Sensitivity" parameters, "Brake" and "Attitude"?
Thanks.
MK
Mine is set at 50 for yaw movement limit and the other two are left at their default configurations. I also set the EXP to .20 for all the settings under "normal" mode and left the defaults for "Sport" mode.
Sent from my SM-G935V using Tapatalk
I'm using the same thing, 50 for yaw. I'm also using .20 on expo for yaw. You don't really have to put a lot of expo on pitch and roll, the gimbal takes those harsh movements out anyway. It's personal preference, but these settings felt pretty good to me. I didn't touch brake and attitude.
50 yaw endpoint, 70 brake, 60 attitude for me, and 90 for pitch gain / 80 for roll gain.
Rudder expo 0.2, others 0.25.
Tap the '...' on the upper right, then tap the drone icon (top one), tap Advanced Settings, then EXP.
Thanks!
I need to lower the sensitivity of the sticks while I learn how to fly this little beast. I'm good on open spaces, but nearly crashed it last night when I nearly fumbled the controller by accident.
Thanks!
enable beginner mode...it will desensitize pretty much everything...
Kazetta
