Oh I got it alright. It's a big complaint in the DJI PFV community that you cannot set the exact height by using a slider. They've been asking for it for years. Because there is no 400 feet in the list. Closest is 6xx. When you are flying FPV, it's easy to zoom right past the limits I guess.welcome to the forum
i dont think @mavic3usa quite got what you were saying ,in his reply ,just keep a check on your height thats all you can do ,and remember the height shown on the screen display is only that above the take off or home point ,and that can vary, so stay just below the 50ft max to allow for this , but unless something goes badly wrong during the flight then you have done your best to comply with the authorisation
Perhaps but as I mentioned with the FPV drone, it moves so quickly and it's sometime pretty difficult to keep it under the limit when you are freestyle flying in controlled airspace. I have been known to bounce off the 190 foot ceiling a time or two. I know when you change the max height, it will also pair down your rth height automatically so it's just one setting for me to worry about. But anyway, correct me if I am wrong about this, I dunno:Opinion: Set it to 500m and forget about it. Learn to manage height continuously as part of your routine flying behavior. Do not rely on the height limit to keep you in compliance.
The reason is this: You may encounter a situation where you may need to exceed the authorized ceiling to avoid a collision with a manned aircraft. Or less critically, suddenly need to ascend to avoid crashing.
In the heat of the moment, you will not think about the max height setting. Instead you'll be in a panic trying to avoid the problem and not understanding why your aircraft is not responding to the left stick.
IMO the max height setting is among the stupidest "features" DJI put in the system. The max height should be fixed at 500m, unchangeable via setting. If you can't maintain a ceiling simply with flying skills you shouldn't be flying at all.
