- Joined
- Feb 19, 2018
- Messages
- 341
- Reactions
- 103
- Age
- 45
same here with a Sand Disk class 10 64Gb any suggestion with the Format mine is extFatFake card? Is it marked as U3?
U1 has a guaranteed minimum write speed of 10MB/s (80Mb/s)I think U1 can only write up to 20mb/s but read at 90mb/s
popped a new Samsung evo 32gb in. 90mb write. Get a slow sd warning. Ideas?
How do u know its bad? Could just be a u1 (slow)....needs a u3Bad card, take back
So what does it mean if a sandisk is u3 v30? Should still be fast enough right?actually you should be following the new "V" standard. v30,60,90. This is the new tested confirmed sustained video write speeds. Forget U ratings, those dont guarantee sustained write speeds.
A U1 and V10 or U3 and V30 are the same thing.actually you should be following the new "V" standard. v30,60,90. This is the new tested confirmed sustained video write speeds. Forget U ratings, those dont guarantee sustained write speeds.
They both have same guaranteed write speeds which have not changed.
The cards are still the same hardware, just a new standard to identify the higher speeds acheived by UHS-II.
A U1 or U3 rating is not a theoretical rating. It's a guaranteed minimum.a U3 and V30 card have the same theoretical speed limit, but the U3 cards were not tested in the same fashion as the V30 cards. so the U3 is not guaranteed to maintain that speed rating, whereas the V30 rating is guaranteed.
From Sandisk:
UHS Speed Class was introduced in 2009 by the SD Association and is designed for SDHC and SDXC memory cards. UHS utilizes a new data bus that will not work in non-UHS host devices. If you use a UHS memory card in a non-UHS host, it will default to the standard data bus and use the "Speed Class" rating instead of the "UHS Speed Class" rating. UHS memory cards have a full higher potential of recording real time broadcasts, capturing large-size HD videos and extremely high quality professional HD and can reach speeds up to 30 megabytes per second.
Video Speed Class or "V Class", was created by the SD Association to identify cards that can handle higher video resolutions and recording features. This speed class guarantees minimum sustained performance for recording video.
