Small thumbnail image each time
Amac123
Uk
Hi guys,
Sorry I am sure there is a setting somewhere, but I cant find it.
Each time a take an still image, as well as the image there is also a small low resolution thumbnail of the image saved as well.
Is there a way of stopping the the thumbnail, to save me deleting it?
Thanks for any help,
Alex
If you shoot RAW+JPG, you will get both images. You can change that to just RAW or just JPG.
This is described in the following link. Scroll down to IMAGE FORMAT:
The JPG isn't a thumbnail though. The DNG files have a thumbnail, but it's embedded into the raw file. Are you seeing a small low-rez thumbnail in addition to the RAW and/or full-sized JPG
Chris
Hi, thanks for getting back to me.
Yes I checked that, I am shooting just jpeg, but I had better double check.
Its definitely not a RAW file the resolution is very very low.
Almost 100% certain its just jpeg.
Thanks for your help.
Also be sure you're looking at images on your SD card. If you're looking at images on your controller device (phone or tablet), those are low rez previews that are not for general use and, as far as I know, you can't turn off.
Reactions: Thomas B
oh, I am not sure about that, I will check in the next couple of days, working for a few days.
Thanks.
Thanks.
As above.., you are looking at small preview images on your phone. Full images and vids will be on the SD card that you can install into the side port of your M2P.
Hi thanks for getting back to me, that makes sense, so thank you.
I have a much bigger problem now, the controller might have failed, but I will do a separate post for that.
tagir
