Some issues with altitude
Sounds like you maybe in beginner mode, check your settings.
Only time I get that is when no / little GPS is available. 98 ft is a set failsafe by DJI. You have to KNOW what your satellite signal is for that area. Some apps provide that before flight, but in the upper right hand of your screen is the satellite signal icon. If it's red - you don't have enough satellite signal and the drone will not go over 98 feet high. There is also a max distance out it will stay within as well.
It's all documented in your manual.
Thanks for information guys, first beginner mode is need to be activated it’s not like you shut off drone rc controller and then again turn on and beginners mode active, it’s not going to be like this, you need activate it by yourself, so yes I am not activated it so this we can pass
another thing about sattelites is more realistic, what I did is: when flying and landing shut of completely drone and rc asi app, and then land again no problems, this also could be a placebo effect but it worked so far for me
nikt_elo
