SROBON Cree
I have a set of 3d printed holders that the lights slip into, then clip onto the arms
If you'd like to mount your STROBON Cree lights on the Mavic Pro arms, I make these mounts:
If mounts aren't your thing, you could stick them right on the Mavic Pro arms with a strong Velcro product like 3M Dual Lock.
Reactions: Hauptmann
I have not tried it yet but I bought Gorilla double sided mounting tape to mount strobes. tape I got is clear rated to 15 pounds is soft and very flexible.
That would work just fine if you're looking for a semi-permanent mounting solution. Just make sure you mount the lights in a location that will not prevent you from folding your Mavic and/or inserting it in a case (if you're using a case).
Will your mounts allow the Mavic to fold? I just assumed it would not be able to.
I love the lights by the way, they work great!
The front arms will fold with the mounts attached. The rear arms will not be able to fold.
Reactions: JamesA
i assume these lights have a port for charging,how long will a charge last and how well do they show in daylight
thx
cool,thx msinger
2hrs means spares needed to last the day
I use Blu Tack, it’s easily removable and very secure when in place. A small piece about the size of a pea does the trick.
iconautomatedsolutions
