My Mavic Pro controller sometimes has a STICK ERROR. I heard about the use of an iPad mini could distort the case causing a stick error. I also heard about magnets causing the error.
I do use an iPad mini but it does not seem to cause the problem. A curious thing that I found is if you start the controller in the laying down position, that is with the sticks vertical, it starts beeping ( I hate that BEEP) and shows STICK ERROR. If I start my controller standing up, that is with the sticks horizontal, it starts fine! NO STICK ERROR and works correctly, even when moved in any other orientation or position. This start up works the same with an iPad mini attached or unattached with the holders folded. I have not tried flying it to see if there is a drift with the sticks untouched.
I have not been able to recalibrate using the DJI Assistant because I cannot get that App to connect. Any one have any ideas? Who knows what evil resides in this complex little bugger
