Does anyone have any idea why this is happening (see photo). The red doesn’t actually show up on the processed images. What is attached are iPhone screen shots. I reset the video settings to factory default and it doesn’t go away.
THANK YOU SO MUCH!!!! This has been driving me crazy for days. I thought something was wrong with the controller, phone and drone. It only occurred when using Litchi. So I thought the app was buggy. Peak Focus Threshold to NONE solved the visual issue.
This was driving me bonkers trying to remove. Your post did the trick! Thank you. Any idea why this feature exists?That is called focus peaking. Its a graphic display of what’s in sharp focus. You can turn it off under the camera settings, sliders bottom right, then gear, upper right.
Its there so you can visually track in on whatever it is you want clear manual focus on, foreground/object in foreground, middle ground or background. Autofocus still isn't foolproof on drone cameras, sometimes manual focus give best results, but on a small screen on a bright day, that can be almost impossible without a clear visual clue.This was driving me bonkers trying to remove. Your post did the trick! Thank you. Any idea why this feature exists?
