Strobe Mounting
Yes, I use them and also sell mounts for them HERE
They look like this but in black:
Reactions: Elton Hammonds
I use strobes and Velcro them to the battery with no problems whatsoever.
Great, I was a little worried that the heat could affect the adhesive. Do you use just plain ole peel and stick velcro?
Thanks
They are available now! You can find them HERE
Also the ARC / ARC II Version is available HERE
Reactions: NetDep
Thanks
The reason I came up with these mounts a couple years ago was because I fly more with the strobes off the aircraft than on and I didn't like the look of Velcro on my birds when not in use.
Reactions: NetDep
Thanks
Yep! No issues whatsoever. I use white velcro on the top since by MA is white, and black on the bottom.
Would be good if the mount was designed at an angle that allowed the strobes to be pointed directly forward and directly backwards, instead of at an angle.
Maybe produce a mark 2 version?
I can do that, I was just trying to keep the form-factor as small as possible. However, the LED's broadcast the light at almost 180 degree angle so it really isn't a big deal that they are angled with the arms.
Reactions: Nigpd
jhon65
