- Joined
- Feb 15, 2017
- Messages
- 133
- Reactions
- 66
- Age
- 79
A story of two MP's and two Litchi missions. Consider MP#1 and MP#2 both flying Lichi missions A and B. MP #2 refuses to accept the upload of Litchi mission B reporting that the flight altitude is too high. During this flight attempt, the following is true
- Litchi mission max waypoint altitude is 380 feet AGL
- RC max altitude setting is 395 ft (in meters)
- Take off in Litchi waypoint mode and climb to 150 ft AGL.
- Attempt to upload Litchi mission B. Mission upload fails, reporting "flight altitude is too high"
- Re-try uploading mission at lower and lower altitude all the way down to 20 ft AGL, and get same result
- The indicated altitude on the iPad seems right on and responds to altitude changes showing no altitudes above any maximums
- Back on ground, verify mission waypoint altitudes are all accurately stated and below 400 feet.
- Put MP#1 on line and it accepts the same mission B upload and flys it fine.
Conclusion --> No problem with Litchi mission B design, but there's an equipment problem somewhere in MP#2.
Now, new location 20 miles away with Litchi mission A; same two MP's
Litchi mission A max waypoint altitude is 300 feet
RC max altitude setting is same -- 395 feet (in meters)
Both MP's accept the mission no matter what altitude I upload from, and both fly it fine.
Same deal with indicated altitude on iPad - seems right on and responds as expected.
Conclusion --> No equipment problem with either MP, but there's a glitch hiding in Litchi mission B
Is there an equipment problem or a mission design problem or a RC settings problem? Thinking about reloading the firmware on MP#2 and dumping the Litchi mission B in favor of a complete do-over. PITA just for troubleshooting, so thought I'd ask here. What am I missing?
Thanks Gang.............. R
