It's actually quite 'dangerous' if you revert to an older drone that doesn't have this feature. I have blown the cobwebs off a couple of P3's and had forgotten you have to manually slow the descent for landing otherwise they just descend at whatever speed into the ground.
I think it has to do with the bottom sensors of all the Mavics. It may be annoying for you at first, but it's probably a failsafe for those of us with less flying experience to insure that the drone lands where you want it to. I suppose you could tape over the sensors. I'm not sure if you could turn them off but not sure why you would want to for the slight annyoyance. As you know if you are in RTH mode it will land itself without any pilot input.
You know I have wondered the same thing, good question. I would also like to know if there is a way to set the initial take off height, I would like it to hovering at about 4-5 feet.So, I just got my first Mavic (air 2) after flying a P3 Pro for aboout 3-years. When you land manually, howcum the drone stops at about half a foot off the deck and won't continue to decend untill you pin the stick?
Is there a way to disable this?
Please post the answer if you find one.
Good luck!
Doesn't that happen with auto take off?You know I have wondered the same thing, good question. I would also like to know if there is a way to set the initial take off height, I would like it to hovering at about 4-5 feet.
Good luck!
It’s designed to check the condition of the landing site, and I guess the only way it can do this is To slow the decent regardless of what the operator inputs.
its a feature of all the Mavics ,mainly to do with the Mavs proximity to the ground, the phantoms had nice long landing legs, so there was plenty of clearance under the drone for the gimbal and props ,on the mavics the fact it hovers, is so the pilot can make sure that the chosen landing spot is suitable ,it does not prevent you from landing the drone yourself ,if you are in RTH mode just cancel the RTH as the drone descends and manually land ,i prefer to fly home manually and land the drone myself ,and the fact it hovers till i give it full down stick is not an issue
I always use RTH and simply monitor the landing, always ready to tap “cancel” and finish manually. Most auto landings are fine. Job done.It's more principle than annoyance. Ask any pilot what they prefer...letting the aircraft land itself, or land it on your own? Most, I've know, including me would choose the latter.
i just find it strange that anyone would want to disable something called" landing protection"Can you not disable "landing protection"? From memory you can not with the mini but maybe you can with the air 2. The work around for the mini is to cover the sensors with tape
Maybe i am misunderstanding you regarding "committed " but I find that even if either of my mavics have entered the landing phase and are in the final descent, throttling up sends it up again even if they are within an inch or less of the ground.
Can’t you just turn off the bottom sensors on The MA2?So, I just got my first Mavic (air 2) after flying a P3 Pro for aboout 3-years. When you land manually, howcum the drone stops at about half a foot off the deck and won't continue to decend untill you pin the stick?
