Sun flare bleeding into the frame
21streetz
Belgium
Hey! I recently got my first drone and obviously I crashed it once but it was not a big crash, I was landing next to my car and the wind pushed my drone to fly into the car( it was about 1 meter high) then it fell into the ground. I looked it very carefugly but didn’t managed to find anything that seemed to be damaged however I’ve experiencing lately whike flying that I have a big *** sun flare bleeding into the image. Even when I have the sun on the side of the drone, I don’t have this issue when having the sun in the back but when it’s either in front or in the corner View attachment 109791it’s really distracting, so my question is: Is it a malfunction because of the crash or is it a common thing with DJI drones? I also want to point out that I also have this problem in video! Thanks in advance for your help :)
You might have cracked/ scratched/ smudged the UV filter in the crash.
There is a sun filter inside the camera?
There is a filter in front of the lens
The filter has the wording printed on it and the spherical lens element is recessed further back
Reactions: THE CYBORG
I’m gonna check it when I’m back and if this is actually the thing that causing the flare and it’s broken, I should send it to repair services, I got the dji care so I will covered?
If it is the UV filter just buy another or get yourself a set of ND filters.
On the MA2, the removable default "filter" is just an empty frame; the UV/protective filter is permanently* attached to the camera, so if you put on an ND filter the cracked filter would still be behind it.
(*Obviously it's removable somehow for repair, but it's not removable in the sense that accessory filters are.)
Reactions: itsneedtokno
OOPS thought it was the same as on the M2P, just twist it off
RichardThiery
