Switching off engine with one hand
mark1769
Sky
Dear community,
This is my first message here. Thank you for existing and hekping!
I will have to land very often by catching my drone with one hand (right) and switching off the engine with the other one (left) while holding my remote controler DJI RC Pro. Is there a setting in the controler I should set to be able to switch off engine with one hand?
Thank you for your help!
Mark
There is no Option for the one hand landing other than learning how to pull the stick down with one hand while holding the controller.
Check out this link where I show i use the one-hand approach
Phantomrain.org
Gear to fly your drone in the Rain an capture the storm.
As mentioned above, just continue pull backward with the left joy stick
Reactions: sarahb
Doesn’t turning the aircraft upside down shut down the motors?
Yes it does but it's a dangerous maneuver cause the drone could slip out of your hands.
It's best to just put your palm below the drone and just it land like it would on the ground. It will fly up at first when it sees you hand but you just need to keep the joystick down and it will slowly land on you the palm of your hand.
elitewikipublishers
