"System Warning Check App"
Sherwood92
California
Greetings. I'm using a Mavic Pro. I had not flown the machine in about 4 months, The first time I powered it, the controller, and the app on my phone up, I'm getting a "System Warning Check App" message on my controller that won't go away, and the message on the phone app is " Calibration Error - Precision Hovering and Obstacle Avoidance May Fail".
I tried removing and re-downloading the DJI Go 4 app three times on my phone but no joy. I tried shutting off the obstacle avoidance system on the drone, but that does not remove the warning. (The places I fly and my uses for the drone do not require obstacle avoidance) So all I really want to do is eliminate the warnings from the controller and app.
I read where I in need to download an "Assistant" app on my desktop, then hard connect the drone to the computer and calibrate the vision sensors. I sucessfully downloaded "Assistant 2" on my desktop, but when I hook up the dorne via the USB cable, the Assistant program doesn't find the drone.
I would welcome any suggestions.
Just making sure…
You need to get the correct Assistant software. At the DJI Download center, search for Mavic Pro, then select Parameter Adjustment Software from the head menu line.
Just making sure…
View attachment 179819View attachment 179820
Success! Thank-you so much.
Reactions: RadioFlyerMan
sharpinjr
