Tablet will not connect
Only one plugged in at s time. USB or micro.
Did you unplug the unused cable from the Micro USB port? The bottom USB port can only be used after that cable has been unplugged.
Reactions: WAXMAN
Before an update tablet connected using SUB port.
After update it will not connect using
USB port but will connect using micro port.
Are u sure you are using a data cable and not a charging only cable?
robqwe
