I searched and couldn't find my question.
On a Mavic Air. Using Free mode in Tap Fly. I understand I select a point above or below the horizon and it will cause the drone to ascend or descend along its flight path. I can use the yaw and rotate the drone while it will continue along its original heading. My other drones call this 'headless mode'.
Now what happens when I tilt the gimbal up/down while it is moving along its flight path? Does that cause the drone to ascend or descend since I am changing the relative position of the horizon?
Example. I enable tap fly and send it forward at a constant altitude. As it is passing the subject I use yaw to rotate the camera to follow the subject. But at the same time I want to tilt the camera downward. I would like the drone to remain at its starting altitude and not divebomb downward as I am trying to capture the shot.
I will test tomorrow if wind calms down but wanted to see if anyone already knew.
Thanks.
Thanks.
