- Joined
- Oct 12, 2016
- Messages
- 29,120
- Reactions
- 32,392
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
I've compiled a list of the top Mavic 2 accessories for May 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic 2 owners are buying and using.
DJI Mavic 2 Battery
Notable features:
Threeking Parabolic Signal Booster
Notable features:
DJI Low-Noise Props
Notable features:
Fstop Labs Foldable Tablet/Phone Mount
Notable features:
PGYTECH Prop Holder
Notable features:
Smatree Mavic 2 Carrying Case
Notable features:
DJI Mavic 2 Fly More Kit
Notable features:
Fstop Labs Landing Pad
Notable features:
Fstop Labs Parallel Battery Charger
Notable features:
DACCKIT Carrying Case
Notable features:
SKYREAT Foldable Tablet/Phone Mount (New Design)
Notable features:
SKYREAT Smart Controller Screen Protector
Notable features:
RCGEEK Foldable Tablet/Phone Mount
Notable features:
SKYREAT Extended Tablet/Phone Mount
Notable features:
PGYTECH Foldable Tablet/Phone Mount
Notable features:
Fstop Labs Carrying Case Set
Notable features:
SunnyLife Parallel Car Battery Charger
Notable features:
DJI Prop Guard
Notable features:
PGYTECH Extended Landing Gear
Notable features:
Arzroic Lens Hood
Notable features:
DJI Mavic 2 Battery
Notable features:
- Created, designed, and extensively tested by DJI
- Guaranteed to work well with your Mavic 2 since the battery is an OEM DJI accessory
Notable features:
- Boosts the remote controller signal to increase its range
- Folds closed for storage
DJI Low-Noise Props
Notable features:
- Guaranteed to work well with your Mavic 2 since the props are an OEM DJI accessory
Notable features:
- Made of high impact ABS plastic
- Attach and detach within seconds
- Able hold a mobile device between the width of 4-12 inches
- 360 ball joint allows the tablet to be adjusted for better visibility
- Folds into a compact form factor for storage
- Hole at base to attach the included lanyard
PGYTECH Prop Holder
Notable features:
- Holds and protects the props during storage
- Made of flexible silicone material
- Easy to install and remove
Notable features:
- Made Of High-density EVA material
- Tough and durable outer case
- Carry with the adjustable shoulder strap or side carry handle
- Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
Notable features:
- Includes a full set of props, two batteries, power bank adapter, car charger, and battery charging hub
- Guaranteed to work well with your Mavic 2 since they are OEM DJI accessories
Notable features:
- 30 inches wide
- Made of a waterproof nylon material
- Includes stakes to ensure the landing pad stays in place
- Fold up and store in the included storage bag
Notable features:
- Can charge 3 batteries simultaneously in 60 minutes
- Able to also charge 2 USB devices
- Comes with a 3 prong cable with ground
- Charger is internally grounded for safety
- Outer shell made of anodized aluminum alloy to help dissipate heat
Notable features:
- Tough and durable outer shell
- Can hold the Mavic, remote controller, 5 batteries, charger, charging hub, and other small accessories
Notable features:
- Made of aviation aluminum-alloy
- Mount can be swiveled sideways to hold a phone
- This upgraded version is more durable since the plastic tightening ring has been replace with a metal ring
- Store the mount and lanyard in the included storage bag
Notable features:
- Made of 9H hardness tempered glass
- Protect the Smart Controller screen from scratches, scrapes, and cracks
- Ultra thin 0.2 mm design to maintain the original touchscreen experience
- Easy to install
Notable features:
- Made of aluminum alloy
- Able to hold a phone or tablet
- Adjustable to customize viewing angle
- Foldable design for convenient storage
- Hole at base to attach a lanyard
Notable features:
- Adjustable height and position
Notable features:
- Able hold a mobile device between the width of 4-10.5 inches
- Made of aviation CNC aluminum
Notable features:
- Separate hardshell cases to protect the Mavic and remote controller
- Water resistant exterior shell
Notable features:
- Charges two Mavic 2 batteries in about 60 minutes
- Able to also charge Mavic 2 remote controller or another USB device
DJI Prop Guard
Notable features:
- Guaranteed to work well with your Mavic 2 since the guard is an OEM DJI accessory
Notable features:
- Extends the landing gear by about 1.4 inches
- Made by high quality ABS & silica plastic
Arzroic Lens Hood
Notable features:
- Reduces sun glare when taking photos
- Shields the camera from the sun and helps protect the camera and gimbal
- Wide opening to stay out of the camera's view
