- Joined
- Oct 12, 2016
- Messages
- 29,144
- Reactions
- 32,438
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
I've compiled a list of the top Mavic Air accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Air owners are buying and using.
SKYREAT Foldable Tablet/Phone Mount
Notable features:
UZOPI Foldable Tablet/Phone Mount
Notable features:
Wrapgrade Poly Skin for Mavic Air
Notable features:
DACCKIT Carrying Case
Notable features:
DJI Mavic Air Props
Notable features:
DJI Mavic Air Battery
Notable features:
Fstop Labs Battery Car Charger
Notable features:
SKYREAT Foldable Tablet/Phone Mount (New Design)
Notable features:
Fstop Labs Foldable Tablet Mount
Notable features:
Yx Battery Charging Hub
Notable features:
PGYTECH Tablet/Phone Mount
Notable features:
RLSOCO Carrying Case
Notable features:
SKYREAT Extended Tablet/Phone Mount
Notable features:
RCGEEK Tablet/Phone Mount
Notable features:
Arzroic Extended Landing Gear
Notable features:
HolaFoto Carrying Case
Notable features:
Yx Parallel Battery Charger
Notable features:
SunnyLife Fireproof LiPo Battery Bags
Notable features:
Want to check out more Mavic Air accessories? A commonly used list of Mavic Air accessories sorted by category is available at MavicHelp.com.
Notable features:
- Made of aviation aluminum-alloy
- Able hold a mobile device between the width of 4-12 inches
- Mount can be swiveled sideways to hold a phone
- Hole at base to attach a lanyard
Notable features:
- Hole at base to attach the included lanyard
Notable features:
- Made with 3M's finest double cast vinyl
- Unique design pattern without corner gaps
- Comes with detailed installation instructions
Notable features:
- Tough and durable hard outer shell
- Interior is lined with a soft microfiber material
- Carry with the adjustable shoulder strap or side carry handle
- Can hold the Mavic Air, remote controller, 5 batteries, charger, charging hub, and other small accessories
DJI Mavic Air Props
Notable features:
- Created, designed, and extensively tested by DJI
- Guaranteed to work well with your Mavic Air since the props are an OEM DJI accessory
Notable features:
- Guaranteed to work well with your Mavic Air since the battery is an OEM DJI accessory
Notable features:
- Simultaneously charge two Mavic Air batteries in 40-60 minutes
- USB port can be used to charge the remote controller or a mobile device
Notable features:
- This upgraded version is more durable since the plastic tightening ring has been replace with a metal ring
- Store the mount and lanyard in the included storage bag
Notable features:
- Made of high impact ABS plastic
- Attach and detach within seconds
- 360 ball joint allows the tablet to be adjusted for better visibility
- Folds into a compact form factor for storage
Notable features:
- Charges 4 batteries one at a time
- 60-80 minute charge time per battery
- Connects to power cable from the OEM DJI battery charger
Notable features:
- Able hold a mobile device between the width of 4-10.5 inches
- Swivels on a ball joint to adjust the angle of the mobile device
- Quick-release thumb screw allows you to attach and remove the mount quickly
Notable features:
- Tough and durable outer shell
- Corners and sides of case are reinforced to protect contents
- Can hold the Mavic Air, remote controller, 4 batteries, charger, mobile device, and other small accessories
Notable features:
- Adjustable height and position
Notable features:
- Aluminum alloy bracket & shaft securely locks the mobile device into place
- Fordable design for easy storage and transport
- Holes at base to attach the included lanyard
Notable features:
- Elevates for extra clearance and stabilizes the landing gear
- A clasp secures each extended leg to the Mavic Air arms
- Made from a strong, mold injected plastic
Notable features:
- Shock absorbent foam interior
- Can hold the Mavic Air, remote controller, 4 batteries, charger, charging hub, and other small accessories
Notable features:
- Charges 4 batteries simultaneously in about 60 minutes
- Able to also charge 2 USB devices
- Covers protect charger terminals when not in use
Notable features:
- Made from PVC flame retardant cloth
- Keeps batteries safe while charging, traveling, and storing
