- Joined
- Oct 12, 2016
- Messages
- 28,311
- Reactions
- 31,135
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
I've compiled a list of the top Mavic Air accessories for June 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Air owners are buying and using.
UZOPI Foldable Tablet/Phone Mount
Notable features:
SKYREAT Foldable Tablet/Phone Mount
Notable features:
Threeking Parabolic Signal Booster
Notable features:
DJI Mavic Air Battery
Notable features:
DJI Mavic Air Props
Notable features:
Fstop Labs Landing Pad
Notable features:
Fstop Labs Foldable Tablet Mount
Notable features:
SKYREAT Foldable Tablet/Phone Mount (New Design)
Notable features:
RLSOCO Carrying Case
Notable features:
Yx Battery Charging Hub
Notable features:
PGYTECH Tablet/Phone Mount
Notable features:
Fstop Labs Battery Car Charger
Notable features:
Smatree Carrying Case
Notable features:
Arzroic Extended Landing Gear
Notable features:
RCGEEK Foldable Tablet/Phone Mount
Notable features:
Powerextra Foldable Tablet/Phone Mount
Notable features:
Hermitshell Remote Controller Case
Notable features:
Techfection Adjustable Tablet/Phone Mount
Notable features:
Hoodman Landing Pad
Notable features:
DJI Battery Charging Hub
Notable features:
Notable features:
- Made of aviation aluminum-alloy
- Able hold a mobile device between the width of 4-12 inches
- Mount can be swiveled sideways to hold a phone
- Hole at base to attach the included lanyard
Notable features:
- Hole at base to attach a lanyard
Notable features:
- Boosts the remote controller signal to increase its range
- Folds closed for storage
Notable features:
- Created, designed, and extensively tested by DJI
- Guaranteed to work well with your Mavic Air since the battery is an OEM DJI accessory
DJI Mavic Air Props
Notable features:
- Guaranteed to work well with your Mavic Air since the props are an OEM DJI accessory
Notable features:
- 30 inches wide
- Made of a waterproof nylon material
- Includes stakes to ensure the landing pad stays in place
- Fold up and store in the included storage bag
Notable features:
- Made of high impact ABS plastic
- Attach and detach within seconds
- 360 ball joint allows the tablet to be adjusted for better visibility
- Folds into a compact form factor for storage
Notable features:
- This upgraded version is more durable since the plastic tightening ring has been replace with a metal ring
- Store the mount and lanyard in the included storage bag
Notable features:
- Tough and durable outer shell
- Corners and sides of case are reinforced to protect contents
- Carry with the adjustable shoulder strap or side carry handle
- Can hold the Mavic Air, remote controller, 4 batteries, charger, and other small accessories
- Mesh pocket in lid for additional storage
Notable features:
- Charges 4 batteries (one at a time) in 3.5 hours
- Connects to power cable from the OEM DJI battery charger
Notable features:
- Able hold a mobile device between the width of 4-10.5 inches
- Swivels on a ball joint to adjust the angle of the mobile device
- Quick-release thumb screw allows you to attach and remove the mount quickly
Notable features:
- Simultaneously charge two Mavic Air batteries in 40-60 minutes
- USB port can be used to charge the remote controller or a mobile device
Notable features:
- Hard outer shell
- Can hold the Mavic Air, remote controller, 4 batteries, charger, charging hub, and other small accessories
Notable features:
- Elevates for extra clearance and stabilizes the landing gear
- A clasp secures each extended leg to the Mavic Air arms
- Made from a strong, mold injected plastic
Notable features:
- Made of aluminum alloy
- Able to hold a phone or tablet
- Adjustable to customize viewing angle
- Foldable design for convenient storage
Notable features:
- Mounts mobile device above the remote controller so it doesn't block the remote controller sticks and screen
- Hole at base to attach included lanyard
Notable features:
- Protect the remote controller from bumps and scratches
- Keep the remote controller sticks attached while in storage
Notable features:
- Tilts up to 45 degrees up or down
- Use the thumb screw to quickly adjust the mount and lock it into place
Hoodman Landing Pad
Notable features:
- 3 or 5 feet wide
- Weighted perimeter to keep landing pad in place without stakes
Notable features:
