- Joined
- Oct 12, 2016
- Messages
- 29,167
- Reactions
- 32,482
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
I've compiled a list of the top Mavic Pro accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Pro owners are buying and using.
SKYREAT Foldable Tablet/Phone Mount
Notable features:
Homga Landing Pad
Notable features:
Threeking Parabolic Signal Booster
Notable features:
UZOPI Foldable Tablet/Phone Mount
Notable features:
DJI Mavic Pro Low-Noise Props
Notable features:
DJI Mavic Pro Props
Notable features:
SanDisk 64GB Micro SD Memory Card
Notable features:
Smatree Battery Charger
Notable features:
Smatree Mavic Pro Carrying Case
Notable features:
Wrapgrade Mono Skin for Mavic Pro Remote Controller
Notable features:
Aterox Gimbal Lock & Camera Cover
Notable features:
Powerextra Mavic Pro Battery
Notable features:
SKYREAT Foldable Tablet/Phone Mount (New Design)
Notable features:
Fstop Labs Battery Charging Hub
Notable features:
Arzroic Lens Hood
Notable features:
Fstop Labs Foldable Tablet Mount
Notable features:
SKYREAT Extended Tablet/Phone Mount
Notable features:
Want to check out more Mavic Pro accessories? A commonly used list of Mavic Pro accessories sorted by category is available at MavicHelp.com.
Notable features:
- Made of aviation aluminum-alloy
- Able hold a mobile device between the width of 4-12 inches
- Mount can be swiveled sideways to hold a phone
- Hole at base to attach a lanyard
Homga Landing Pad
Notable features:
- 30 inches wide
- Made of a waterproof nylon material
- Includes stakes to ensure the landing pad stays in place
- Fold up and store in the included storage bag
Notable features:
- Boosts the remote controller signal to increase its range
- Folds closed for storage
Notable features:
- Hole at base to attach the included lanyard
Notable features:
- Created, designed, and extensively tested by DJI
- Guaranteed to work well with your Mavic Pro since the props are an OEM DJI accessory
- Slightly quieter prop noise
- Slightly increased flight time
DJI Mavic Pro Props
Notable features:
Notable features:
- U3 memory card
- Fast enough to record any type of photos/video produced by the Mavic 2
- Plenty of storage space to capture all of the needed photos/video
- Transfer files to/from the memory card with the included memory card reader
Notable features:
- Charges 3 batteries (one at a time) in about 140 minutes
- Charges faster than the OEM DJI battery charger
- USB port can be used to charge the remote controller or a mobile device
Notable features:
- Made of high-density EVA material
- Carry with the adjustable shoulder strap or side carry handle
- Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
Notable features:
- Made with 3M's finest double cast vinyl
- Unique design pattern without corner gaps
- Comes with detailed installation instructions
Notable features:
- Single piece that both locks the gimbal in place and covers the camera to protect it
- Made of high-impact plastic
- Easier to attach than the OEM lock and cover
Notable features:
- Comparable performance to the OEM DJI Mavic Pro battery
- Compatible with all Mavic Pro battery accessories
- The best 3rd party battery replacement if you're looking for something other than OEM DJI batteries
Notable features:
- This upgraded version is more durable since the plastic tightening ring has been replace with a metal ring
- Store the mount and lanyard in the included storage bag
Notable features:
- Charges 4 batteries one at a time
- 60-80 minute charge time per battery
- Connects to OEM DJI car charger or power cable from the OEM DJI battery charger
- Display shows the charge voltage, charge current, and overall battery status
Arzroic Lens Hood
Notable features:
- Reduces sun glare when taking photos
- Shields the camera from the sun and helps protect the camera and gimbal
- Designed to stay out of the camera view (even when flying in sport mode)
Notable features:
- Made of high impact ABS plastic
- Attach and detach within seconds
- 360 ball joint allows the tablet to be adjusted for better visibility
- Folds into a compact form factor for storage
Notable features:
- Adjustable height and position
