- Joined
- Oct 12, 2016
- Messages
- 28,415
- Reactions
- 31,305
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
I've compiled a list of the top Mavic Pro accessories for May 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Pro owners are buying and using.
SKYREAT Foldable Tablet/Phone Mount
Notable features:
KINBON Landing Pad
Notable features:
Threeking Parabolic Signal Booster
Notable features:
Fstop Labs Foldable Tablet/Phone Mount
Notable features:
Smatree Mavic Pro Carrying Case
Notable features:
SanDisk 64GB Micro SD Memory Card
Notable features:
Smatree Battery Charger
Notable features:
DJI Mavic Pro Low-Noise Props
Notable features:
Arzoic Gimbal Lock & Camera Cover
Notable features:
SKYREAT Foldable Tablet/Phone Mount (New Design)
Notable features:
Fstop Labs Battery Charging Hub
Notable features:
DJI Mavic Pro Battery
Notable features:
AxPower Accessory Pack
Notable features:
RCGEEK Foldable Tablet/Phone Mount
Notable features:
CamKix Accessory Pack
Notable features:
SKYREAT Extended Tablet/Phone Mount
Notable features:
Arzroic Lens Hood
Notable features:
PGYTECH Foldable Tablet/Phone Mount
Notable features:
DACCKIT Mavic Pro Carrying Case
Notable features:
DJI Goggles
Notable features:
Notable features:
- Made of aviation aluminum-alloy
- Able hold a mobile device between the width of 4-12 inches
- Mount can be swiveled sideways to hold a phone
- Hole at base to attach a lanyard
KINBON Landing Pad
Notable features:
- 30 inches wide
- Made of a waterproof nylon material
- Includes stakes to ensure the landing pad stays in place
- Fold up and store in the included storage bag
Notable features:
- Boosts the remote controller signal to increase its range
- Folds closed for storage
Notable features:
- Made of high impact ABS plastic
- Attach and detach within seconds
- 360 ball joint allows the tablet to be adjusted for better visibility
- Folds into a compact form factor for storage
- Hole at base to attach the included lanyard
Notable features:
- Made of high-density EVA material
- Carry with the adjustable shoulder strap or side carry handle
- Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
Notable features:
- U3 memory card
- Fast enough to record any type of photos/video produced by the Mavic Pro
- Plenty of storage space to capture all of the needed photos/video
- Transfer files to/from the memory card with the included memory card reader
Notable features:
- Charges 3 batteries (one at a time) in about 140 minutes
- Charges faster than the OEM DJI battery charger
- USB port can be used to charge the remote controller or a mobile device
Notable features:
- Created, designed, and extensively tested by DJI
- Guaranteed to work well with your Mavic Pro since the props are an OEM DJI accessory
- Slightly quieter prop noise
- Slightly increased flight time
Notable features:
- Single piece that both locks the gimbal in place and covers the camera to protect it
- Made of high-impact plastic
- Easier to attach than the OEM lock and cover
Notable features:
- This upgraded version is more durable since the plastic tightening ring has been replace with a metal ring
- Store the mount and lanyard in the included storage bag
Notable features:
- Charges 4 batteries one at a time
- 60-80 minute charge time per battery
- Connects to OEM DJI car charger or power cable from the OEM DJI battery charger
- Display shows the charge voltage, charge current, and overall battery status
Notable features:
- Guaranteed to work well with your Mavic Pro since the battery is an OEM DJI accessory
Notable features:
- Protect the remote controller sticks and screen while in storage with the remote controller stick protector
- Lock the gimbal in place and protect the camera with the gimbal lock and cover
- Shield the camera from the sun and protect the camera with the lens hood
- Protect the motors while in storage with the silicone motor caps
- Add 1.2 inches to the landing gear with the extended landing gear
- Keep the props folded in place while in storage with the prop straps
Notable features:
- Made of aluminum alloy
- Able to hold a phone or tablet
- Adjustable to customize viewing angle
- Foldable design for convenient storage
Notable features:
- Protect the remote controller sticks while in storage with the remote controller stick protector
- Keep the props folded in place while in storage with the prop locks
Notable features:
- Adjustable height and position
Arzroic Lens Hood
Notable features:
- Reduces sun glare when taking photos
- Shields the camera from the sun and helps protect the camera and gimbal
- Designed to stay out of the camera view (even when flying in sport mode)
Notable features:
- Able hold a mobile device between the width of 4-10.5 inches
- Made of aviation CNC aluminum
Notable features:
- Hard outer shell is tough, durable, and waterproof
- Inside of the case is lined with a soft microfiber material
- Can hold the Mavic, remote controller, 5 batteries, charger, charging hub, and other small accessories
DJI Goggles
Notable features:
- Dual 1920 x 1080 HD screens
- Integrated touchpad to navigate through menus within the goggles
- HDMI input and 3.5mm audio jack
- Up to 6 hours of battery life
