Transferring video back to DJI go app for editor
TheDigitalDove
Australia
Shot 4K video on Dji Go ap, iPhone X, Osmo 2, transferred to iMac and deleted. i wanted to use as quick reference from the autoedit video that remained in the Editor>create tab. However short of playing iin the app, i cant generate a video , or change anything, as the originals were transferred out.
Am i correct that?
1. the 4k video shot cannot be reimported but the lower resolution video can
2, Using itunes i was able to drag all the files back to the DjiGo documents section but not put them into the hg300 stortage folder is it required in the correct folder to be accessible and create another autoedit or save out the old one?
3. Am I correct the only remaining solution is to use the dji go app to import lower res 1080 files from sd card on drone, or photos album on iphone? Would be great if 4k could go back the same way and with the same file names ( ie not from photos album)?
Remove the memory card and copy the original 4K video to your computer with a memory card reader. Will be on the memory card till you delete it.
viliuss23
