Tricks to flying straight?
Don't remember ... think the main way to change speed is with the slider on screen when you're in the tapfly mode.
That is also my recollection. In forward and backward mode, the slider sets the speed and the distance of the tapped point from the horizon line dictates the climb/descent rate. In free mode, the speed slider still determines speed but you have additional control over yaw. In all three modes you have full control over the gimbal which is why I like TapFly. You can really do great reveal shots when you don't have to worry about controlling speed and direction and instead fully concentrate on the camera's pitch. Any way, these modes require a little practice before you actually can use them so all these details will become clearer when OP does a test run.
@Photogad ... maybe try stick extensions for finer control. ... or use the methods discussed above and modify the speed of your video in post. I do both routinely.
Litchi and Dronelink can both be programmed onsite to do this using their "Cable Cam" modes.
Set a starting waypoint and fly to an ending waypoint with the framing you want at each. Then you can run the path forward or backwards with smooth interpolation between WPs.
This will be much smoother and predictable than most can do hand flying.
I have found that if I want to move more smoothly on any of the 3 axes, I put pressure on the side of the stick, not move the stick with my thumb on top of it. SAR pointed out that this allows the secondary input direction springs to keep that secondary axis in a neutral position.
Not sure if I explained this accurately but it works great for me when I want smooth movement on a single axis, like yawing.
Reactions: Thomas B and sar104
I might also think about making some kind of device with a channel in it to affix to the controller so that the stick can only be moved up or down and not sideways
Hmm, something like a printed V that you can attach to the controller under that left (and above right ? ^ ) stick(s), that the stick(s) can come down into, and not move sideways.
Would solve your problem for those shots.
I made a simple mod to my Phantom 2 Vision to smooth out my yaw....large rubber bands around the left stick horizontally that offered more pressure when moving the stick left/right (yaw) but not up/down (throttle). Inelegant but it worked.
Agree wholeheartedly. That is my method also.
I still dont get the problem here.
Lowering the sensitivity should do the trick. And you are not doing any complex cinematic movements, it's just flying back and upwards...
What about waypoints 2.0.
Waypoint 1 in-front of your target at low height
Waypoint 2 in-front of your target at just above your target.
Waypoint 3 is your end point
Add POI your target to all waypoints.
Reactions: pelagic_one
Personally, I would use waypoints as you can set the camera angle as well from start to finish.
EDIT:You beat me by a few seconds...
I do a lot of real estate videos and agree the dronie is great for a closing shot. I like to use waypoints (either DJI or Litchi work well) for this type of dronie. 1: You can set waypoints to ensure you avoid trees. 2. You are free to adjust the gimbal. 3. You can do same maneuver over and over to get it perfect. 4. You can set speed to say 10 mph so speed is consistent and then you can speed it up as needed in post to time it to music or trim the video. It takes some practice setting waypoints but once you are skilled at it, it saves time.
Reactions: OurAngryBadger
Another advantage of using waypoints over Tapfly is your path does not have to be a straight line. With three or more points you can get a nice curve.
I generally find that pulling back a ways with the drone gaining altitude slowly to begin with and then increasing more rapidly as the distance from the subject get greater creates a more cinematic reveal than a straight line.
I guess I'll have to try out the waypoints feature. Can you adjust speed with it?
I understand about speeding up the video in post, I do that, but it's not always feasible.
For example I did a commercial property shoot recently where the roadways were visible. I could speed it up about 150% or so but if I went any higher it made the cars zipping by look like they were going at lightspeed, very unrealistic. Unfortunately in tripod mode the drone moved so slow (and it was such a massive building) I would need to speed it up at least 600% in post to get the whole clip down to 10 seconds or less
Yes. There is a slider to set the speed. It will be the same speed for the duration. I normally fly to the furthest point and set Waypoint 1 and then fly down to the starting point to set Waypoint 2 to make sure it is a clear path. Then set the speed and a couple other settings you will see in the app and hit go. BTW, with Litchi, you can do these waypoints, on your computer, save the mission, and when you open the litchi app on your mobile device your “mission” will be ready to go. I want to emphasize this takes practice, but learning how to use the various autonomous modes is fun, and unless you are a highly skilled pilot, your videos will look much more professional. It is very hard to control gimbal and sticks simultaneously. Autonomous modes eliminate unwelcome yawing and inconsistent speeds so you can focus on framing the shot, as if you were the camera man on a DJI Inspire with two pilots.
Litchi's Cable Cam function will let you frame your view at each waypoint (onsite) and then will interpolate the pitch (and/or yaw} smoothly between them for results that are hard to replicate by hand unless you are very good and steady.
Dronelink has even more flexibility than Litchi and is free for non-commercial use.
marcusjohn3684
