TRNC Turkish Republic of Northern Cyprus
Page 1
Unmanned Aerial Vehicle (DRON) User Manual
Within the TRNC Airspace, small UAV drones
special conditions / restrictions.
A. For flights with DRONs whose maximum weight does not exceed 500 grams, above ground level
from the Civil Aviation Department for flights up to a maximum height of 50 meters (150 feet)
permission / authorization is not required under the following conditions:
1. Trained by the operator / operator to use this aircraft system
being
2. Alcohol, drugs, which affect the judgment and reaction of the operator / entity, and
not acting under the influence of other substances
3. Any substance that may cause damage or damage to the operator / operator during the flight.
or to prevent or prohibit the discharge / discharge of the material.
4. The operator / operator assures that the flight is safe and that the flight is immediately
can fly the aircraft if it is reasonably satisfactory that it can be cut.
5. Operator / operation may collide with other aircraft, persons, vehicles, vessels and structures.
direct, unaided visual contact with the aircraft not exceeding 150 meters
to protect
6. Each operator / operator is allowed to operate one aircraft at a time.
7. In residential, crowded or very crowded outdoor alliance / organizations
To obtain a flight permit from the Civil Aviation Department 5 business days prior to any flight
It is mandatory.
8. Ensure a safety distance of 150 meters from settled or crowded areas and
operator, supporting personnel, tools and equipment from humans, animals, plants and etc.
keep other supporting assistants at a distance of 50 meters.
9. At least 6 km from any airport / airport and 1.5 km from the heliport
Ensure safety zone at distance.
10. During the take-off and landing of the operator / operator under the control of a 30-meter
exclude operator, or other persons from the security area.
11. Forbidden zones, borders, dangerous areas specified in the Civil Aviation Department aviation publication
and within the reserved areas and military settlements, public settlements, archaeological excavations
places, on or around private facilities,
flights are not allowed.
12. Aerial photographing of military forbidden zones / facilities is strictly prohibited.
13. Police and municipal authorities should be informed by the operator / company if necessary.
14. DRON operators / operators must register with the Civil Aviation Department. in savings
contact numbers and names of the DRON (Unmanned Aerial Vehicle)
provide details and specifications ( model and serial number ). E-mail:
I [email protected]
15. Only in cases where meteorological conditions are met, sunrise-sunset
between the hours and at least 2km of sight.
16.Do not fly carelessly or recklessly with your Unmanned Aerial Vehicle (UAV) - people or aircraft
you will be punished.
Page 2
B. DRON to be flown in approved aircraft design facilities under the following conditions
No special permission is required by the Civil Aviation Department for
1. Training of the operator / operator to use this aircraft-related system
have won
and does not act under the influence of other substances
3. Any operator / operator may cause damage or damage during flight.
prevent or prohibit the discharge / discharge of the substance or material
5. Operator / operation with other aircraft, persons, vehicles, vessels and structures
to avoid collision, no more than 500 meters horizontally,
it will maintain unaided visual contact.
6. The flight should not exceed 400feet (120 meters) above ground level .
7. Ensure a safety distance of 150 meters from settled or crowded areas and
people, animals, structures, etc.
and keeping other supporting assistants at / beyond 50 meters.
8. When taking off and landing under the control of the operator / operator, a
9. All flights are third party financial for property damage and physical disability / injuries
liability insurance must be secured.
C. Any DRON (Unmanned Air) that does not meet the above conditions or is over 500 grams.
Special Permit issued by the Civil Aviation Department is required for the flight. This
written application must be submitted to the Civil Aviation Department for evaluation.
Film and TV production, advertising agents, marketing or
extensive land improvement / real estate development on industrial sites related to other promotional activity
or for photographic work on research or infrastructure inspection, the relevant DRON (Unmanned Weather)
Intermediary operators apply to the Civil Aviation Department for a
The scope of the applicant's flights may be
coordinates, altitude, and operator information to the Civil Aviation Department
and obtain permission for the region to fly.
Form .........- Application form for aerial photography must be completed. Scheduled applications
must be submitted at least 5 working days prior to the operation.
All applications will be evaluated from case to case.
Page 3
Important Notes (applies to all DRON operators)
1. Directorate of Civil Aviation DRON (Unmanned Aerial Vehicle) operation / operation permits
The process aims to keep flight safety in the forefront. Collect photos, information or advertising
other purposes do not extend rights.
2. Collection, storage and use of photographs or information
regulations. DRON (unmanned aerial vehicle) operators applied this
ensure that they comply with the requirements and exemptions.
3. The permission of the Directorate of Civil Aviation shall only aim at the safety of the flight. Police and other
legal permission for violating the legitimate interests of legal bodies
It does not.
4. Operator / operation fully safe from the safe operation of Dron (Unmanned Aerial Vehicle)
It is responsible.
Imported Technical Compliance
Imported technical conformity permit for IHAs with a maximum weight of 500gram - 25kg
to be
The following information and documents are sought.
1-Product catalog containing technical specifications of UAV and its systems,
2-UAV and systems production year and manufacturer country,
3-Proforma invoice including brand, model serial number information and Customs Legislation
availability.
4-Forensic registration certificate of the importer of UAV and its systems,
5-Contact information of real / legal person importing UAV and its systems,
REGISTRATION PROCEDURES
For each UAV brought from abroad or purchased from importer companies
Registration to the "Registration System" is mandatory.
For UAVs with maximum weight not exceeding 500 grams-25kg
It is entered.
1-Manufacturer of UAV and systems, brand and model, serial number,
2-Production place and date of IHA and systems,
3-Maximum take-off weight of UAV,
4-ID number, address and contact information of the owner / operator of the UAV and systems,
5-Register of the owner / operator of the UAV and its systems,
Reactions: BlackTR48
NY NICKY
