Just wandered if the new TXTlogToCSVtool.exe works on the newer flight records, last i heard it didnt
Part of the log is translated, few tables are broken. Not working right now. I was trying to make a profile for Dashware for the Mavic 3 but need some work to make it work.Just wandered if the new TXTlogToCSVtool.exe works on the newer flight records, last i heard it didnt
You'd need TXTlogToCSVtoolMM.exe wouldn't you?
What drone is that one? let me get you my files.I have been semi successful in creating a profile, I downloaded a CSV file from AirData website, I can get everything working except distance and max distance, the values in the CSV are massive.
I used the Flytrex dataset as it had the map values, then added Satellites to it and then had to remap all the other values for the gauges.View attachment 138824
Try the two XML files.
Copy DJI Mavic MM-MA2-M2P.xml (Data Profile) to C:\Users\your_username\Documents\DashWare\DataProfiles
Copy CustomDataTypes.xml (Custom Data Types) to C:\Users\your_username\Documents\DashWare\Settings
Import included gauges (.dashware extension) from Gauge Toolbox in DashWare
I have a profile that I am testing for the Mavic 3. Also,Thanks for the files but they are no different to the ones I have and dont work with a CSV from airdata website, if you try to convert the txt file the tool just hangs
I have a profile that I am testing for the Mavic 3. Also, I guess will work with the other drones but I need to confirm. I have everything working except the vertical altitude because airdata does not provide that in the CSV and the joystick inputs because they change the way they center from 0 to 1024 and I need to figure it out. but I can share the profile I am working with now and see if works for you. In case do not work with other drones i will be creating separate profiles for each drone.
Also, keep in mind this is made for imperial. I need to work on fixing the metric system as well. It just takes time. I have long hours working with that.
If you need instructions on how to install that let me know.
Do not use the converter. Use the Airdata CSV. The profile is adapted to that CSV. I need to send an email to airdata and see if they can provide the Vertical Speed data in the CSV.
Did you use your profile or the profile I gave you?
Mine are working perfectly. Still missing the Vertical Speed because the zspeed does not work. Also the Sticks imputes. Still working on that. Here is my Gauges. Everting in one bar to keep it clean.
View attachment 138948 in one bar. Looks more clean.
You need to install the gauge. I did made this video like a year ago and I explain how to do it.Can you send the gauge please mate, i tried your file again and its still a no go with my XML file
I will do a new video since there a different way to work with the CSV and i will ad new techniques.
