TXTlogToCSVtool.exe does it handle the newer flight logs yet?
Can you share the profile with me to see how you solve the zspeed?
here you go bud let me know if it works, ive included my gauge, i just had to edit this as the max speed wasnt working correctly
Reactions: zeusfl
I am now in a road trip for thanks giving but in my way back I will test
Please see my last message, I had to upload a new file as the max speed wasnt correctly working
I have that working. Let’s fix the profile between both and let’s post it for everyone benefit. I will do more gauges to support every drone.
I can do that, I have the original set of V4 files that were posted on here a while back, they all work with the exception of the long gauge, which im working on and until Airdata (I have contacted them) let us download a Metric CSV file I cant get the Metric gauges to work.
Im currently looking at the stick assignment
There is not necessarily. I can do math converters in the profile. That part is easy.
Reactions: Exphantomflyer
Ive got AD to change the stick values to what they should be, ill try a test later today
Tested and working fine mate
@zeusfl
Just waiting on recording time to be added, the total distance is adding ascent/descent distance, Ive asked Airdata if that can be looked at.
I have to start looking into Metric settings now.
Reactions: zeusfl
T
@zeusfl
That was a great job. We need to talk about how you resolve that for the stick component. I have already resolved the other parts.
Which recording time are you referring to?
I guess that will be the CAMERA_INFO.videoRecordTime from the old format of the TXTlogToCSVtoolMM.exe utility that now is broken. We are using the AirData CSV file that does not contain many of the fields.
We are trying to match all the fields from airdata CSV file to dashware gauges and formulas.
T
I didnt, the techs at Airdata added new columns for stick percent that use the 100 range, ive asked for a couple more columns as well, see previous posts,
Ive got metric sorted but for some reason I cant get it to work, ive copied the settings I use for imperial but it still shows negative numbers when it climns and postive numbers when it drops
I have a gauge that shows the amount of time the quad has been recording for, it worked im sure on the mini, I will have to run a flight with an early app version to be sure it was there, it may have been a Mavic Pro (GO4) thing
I managed to get a Mavic 3 flight and video from a Facebook mate and have tested it with that and all working fine, I.m just waiting on Airdata to sort out the last column (rec time) and I think the project is complete
Nice !!! The Mavic 3 has a 4S battery. You need to add a C4 Just copy and paste the C3 and move it down and rename to C4 and the copy and paste the bottom formula and re-attach it to the C4 voltage formula. I can do it for you if you want. We can add more information, I have a new update for that. I still need to figure out the Vertical Speed. I will see if i have time this weekend to work with it.
Did not realise that when I added the 3rd cell, but I've changed it now to a 4 cell and added a new set of files to this post as a zip file.
I was hoping that Airdata would have got back to me by now, they have had a week to sort out the other things I have asked for, maybe as xmas they may have finished work, shame as I wanted this wrapped up before new year.
realdealathletix
