Does anyone use the UAV app? If so what are the settings specific for it to set for the MM please? Screenshots would be appreciated.
Thanks
Thanks
You’re correct, I forgot about the temperature setting. I set mine to 20 degrees F but I sit in a warm car and fly when it gets that cold. I have read that some fly in much colder weather. Read up on cold weather flying if that applies to you. I’m sure there are multiple threads on this forum about that. I learned there are some precautions to keep you out of trouble.Is that the only setting, to set the gust max and a height? I thought they were maybe more that’s all.
Thanks
With the exception of Visibility, none of those have any effect on drone flying and can be safely ignored.Cloud cover, visibility, min sats, locked sats, KP?
None of those settings in UAV Forecast make any difference.Really, so the amount of sats doesn’t matter! Not according to manual, and the MM now won’t take off without 8 locked.
You will find people that will tell you KP index might have an undefined impact on GPS satellite reception.The KP does affect I believe the compass or something and can cause problems?
"WINDY" is an invaluable site. So much info available.I use it every time.
Now I've also added two websites to my home arsenal: windy.com and ventusky.com
My favorite feature of Windy is the map with the designation for local weather sites. You click on one of those and you get a graph of ACTUAL wind min and max. I have seen wind forecasts of 20 mph gusts and then looked at the Windy graphs near where I am flying and found the actual gusts have not exceeded 6 mph."WINDY" is an invaluable site. So much info available.
