UK South
Hi, Camerart, welcome to the forum, from Hauptmann in north Texas (DFW Area)!
I like the Mini 4 Pro. For my money, it's between the Mini 4 Pro and the Air 3 S. Though the M4P doesn't handle wind as well as the larger drones, its sub 249 gm weight helps it duck under some of the more arcane drone regs in UK, Canada and the US.
I've been making and flying drone for a number of years
I can see from your other post that you are getting a lot of great advice, but you really need to help the members offer advice. Tell us what you really want to do with your drone, Photos, Video, First Person Video (FPV as in flying with goggles…) just fly for fun, etc…, and then what your budget is… based on your wants, desires, and budget, the cost of drone can vary over a thousand pounds (UK money, not weight… L o L . . .)…
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Leviticus
