Unable to take off due to visual Sensor error. How I solved it.
Shiva666
Malaysia
Hi all,
Quite recently, I have seen a number of complaints regarding the Mavic Mini unable to take off from the ground due to some error in the visual sensor. Even I had that problem. After recently updating the firmware to the latest, I discovered that my drone is facing the same issue. here is how I solved it. I followed the upgrade instructions as per dji advise.
1. I connected the drone to the computer, using Assistant 2 and Updated the firmware again.
2. I connected the controller to the computer and updated it again'
3, I reconnected my drone and slotted in the sd card and turned on the drone while it is connected to the computer.
4. I connected my phone to the remote and turned on the unit.
5. Disconnected the drone from the computer. Turned it and the remote off.
6. Restarted the drone and controller.
The camera is finally working. Hope the same works for you guys.
Thanks.
Reactions: juls332
gimfbsx
