Unique Specs for COA application
hbrlasvegas
Las Vegas
Hi I'm trying to find the following specs on the Mavic Pro...
Turn Rate (deg/min)
Bank angle (degrees)
Approach speed (kts) - pretty sure this is for normal aircraft as they approach the runway...
Avionics Equipment Suffix Type (T, X, or U)
Is there a transponder? (I think no)
See attached screen shot of the form...
Thank you for any help
Still searching for this info years later!!! any help???
MavicPro Performance Characteristics for COA Application
Approach Speed (kts)?
Launch Method?
Recovery Method?
Turn Rate (deg/min)???
Can't find this anywhere!
cbooth
