USB-Speed of Mavic 3 (non-Cine)
fzahn
Speyer, Deutschland
Hi,
today i wanted to transfer footage from my Mavic 3 using a USB-C to USB-C cable. Unfortunately it only connected with USB2-speed, which is really slow. Does the USB-port not support higher USB-speeds as USB-2 or is a special cable needed? I know, that we do not have the Lightspeed-Port of the Cine on the normal Mavic 3, but i was hoping to get at least USB3-speeds....
Regards,
Florian
Copy to the micro SD card, it’s quicker.
Hi,
but that was not the answer to my question. My question was, if the USB-port Is only capable of USB2-speeds or if I need a special cable for higher-speed.
I was not asking, if i should better use a sdcard-reader.
Regards,
Florian
Hi,
Regards,
Florian
I would think the USB port would be 3.0. Not that I've ever tried to use it for file transfers. The Mavic 3 supports direct wifi transfer at 80 MB per second which is all I've ever used.
Reactions: GadgetGuy
Hi,
Regards,
Florian
The thicker, removable USB charging cable on the charging brick is USB 3. Use it. It is also used for FW updates when the drone is connected to a computer.
rstegner
