Are you using ND filters?
If you are shooting photos, ND filters might not do anything for you. For landscape photos such as the one you have posted above, you should probably use the AEB mode with 5 shots, and merge parts of them together in your post-processing software. It takes time. Sometimes conditions are just not going to be right for the subject that you are trying to capture. At the very least you need to shoot DNG format photos and process those.Can someone please give me basic settings to start with please...im starting to loose hope.....And how to take a shot looking at the sun showing the sun not a white blurry glare ? Thanks
Excellent adviceIf you are shooting photos, ND filters might not do anything for you. For landscape photos such as the one you have posted above, you should probably use the AEB mode with 5 shots, and merge parts of them together in your post-processing software. It takes time. Sometimes conditions are just not going to be right for the subject that you are trying to capture. At the very least you need to shoot DNG format photos and process those.
