Vision sensors calibration error, help!
networth
First off, DJI assistant 2 doesn't work very well. It disconnects when I finish forward calibration and goto downward calibration. This has happened 9 times now since yesterday, so for sure, it's not the issue of my cable or computer.
It's something to do with the DJI firmware.
I have even reset the mavic and also refreshed the firmware from DJI assistant 2.
Still same issue.
Now I just fired up the mavic and it kept on showing me the red errors of vision sensors.
If I try to calibrate it from the phone app itself, nothing happens.
Has anyone done the vision sensors calibration from their phone app ?
I see this.
I have already tried drawing a circle holding the camera all 3 ways, facing myself, facing outside facing diagonal whatnot. Still nothing happens on this calibration screen.
If you are using Windows it is a firewall and driver issue, do a search for "sensor calibration" and you will find the fix.
Regards,
-d.
-lose the crocs
Still same issue.
I see this.
See my post above.
Regards,
-d.
-lose the crocs
No. I'm on OSX and I have calibrated the same using the same MacBook pro before too. Never had issues.
So if you have calibration on other computers, it is not the drone correct?
Regards,
-d.
Regards,
-d.
I mean I have calibrated the same mavic in same computer before too. It never had this issue. But now it is not happening
Regards,
-d.
I guess I meant it is the program , is there another computer you can use or you can roll back dji assist?
Regards,
-d.
Make sure you don't still have the protection stickers on your forward and downward camera lenses.
Regards,
-d.
So you suggest to try with a new windows computer and refresh the firmware again on the new PC ?
Here I will explain how to get it all to work on windows 10. PLEASE READ DESCRIPTION FIRST ON THE VIDEO!
how do i remove those?? im having issues sometimes and i think i never removed my stickers... unless it did not come with any
tortoide
