Walkie talkie strapped on mavic 2
Van Shteffy
I know that a mavic 2 can lift a walkie talkie . It would be great to talk with someone a ways away. I have voice operated walkie talkies and was wondering if they would interfere with the smart controller. I think this is a unique idea. You read it here.
There is the risk of interference but a more obvious limitation is the sound of the propellers drowning out any chance of communicating. Now, if you dangle it down a ways .... maybe?
Reactions: Capt KO
There is no Interference.
Several of our clients use the Made for Drone Walkies on the Mavic 2 in place of the Enterprise speakers.
They make a high end model and a low end but no middle ground.
They do add weight so it not possible to be fully loaded , something has to give , so its last no the line for search and Rescue
but can be easily added in place of the Spot Lights and laser.
Phantomrain.org
Gear to fly your Mavic in and out of the Storm.
Search and Rescue can add them as needed.
the only problem you will have is prop noise , that's why the drones are not fitted with microphones for video. and it may effect the controller signal as well
Jiddles
