waterdamaged mavic air 1 , need battery pinout
robcampie
laren
i have a water damaged drone, got it to tinker with, only comes without battery.
Now i have opened it up, seen a lot of corrosion and decided it needed a good ultrasonic bath with demineralised water and isopropyl alcohol.
After that i dried the mainboard and placed it back into the air.
now i needed to test it, so i put 12v on pin 3-4 and the pins at the right 2 form the end.
the drone powered on, fan made a lot of noise. but no wifi signal.
I was wondering, is it possible to power the drone without a genuine battery?
i know sometimes the pins all have a purpose, and so i thought maybe there is hope when i try to power it with a genuine battery.
Would like to hear from someone who can send me in right direction.
And it would be cool to find a solution for these crazy expensive batterys
Hello from the Hoosier Heartland robcampie.
I found this page that has the pinout for The Spark, Mini 1, 2, and the Air 1.
Good luck and welcome to the Forum. :cool:
Reactions: hiflyer201
Beats me. ?
I'm not a battery expert.
This post discussing a Mavic Air battery may shed some light.
Dji Mavic Air batteries have authentication check with a drone over communication port.
The drone could be powered up from hobby 3S LiPoHV battery but it will not allow to take-off. Dji Go 4 will pop-up 'authentication failure' warning.
To let it start the motors, one should enable 'non-DJI' battery option in engineering settings through the older Dji Assistent 2 which has hidden debugging menu.
Liger210
