Way Points won't start route after programming
AVInteractive
I've successfully flown about a dozen routes using the waypoint feature, however my Mavic 2 now refuses to start.
I have programmed both pre-flight using the screen to mark points, and manually flown the route and added the points, on both attempts after hitting go, then the route profile info and finally start nothing happens the drone just hovers where it is.
Any clues as this did work a few days ago?
thanks for and advice
Do you have the mission speed set to 0?
I don't think so, funnily enough that was the feature I was trying to test on this flight. I wanted the drone to fly at a steady speed on all way points where as previously I had a different speed on each point.
I presume the Mission Speed setup is in the final page after GO and before START ?
Yea if you set it to 0 you have to push the right stick forward to make it go through the waypoints which is a cool feature actually. Allows you so manually control the speed
bigkap
