Weak GPS notification
not sure , using waypoint mode may solve the problem , the drone wont depend on your controller for instructions. its a possibility, on my mavic 2 pro there is an option to continue mission on loss of signal. if you set the last point near you . you should be ok
Waypoints will solve issue with RC connection, but not necessarily with GPS connection.
It's worth trying though - with 8-11 satellites there should be enough accuracy to proceed to the next way point where the strength might improve.
I would say watch the drone and be ready to terminate mission, if anything odd happens.
This may be the problem? My FAA # is printed with one of those metallic label makers???
I removed the label... Today I had 15 strong SAT's. Flew 2 missions, recorded a perfect orbit! Thanks all for your input and Ideas. Mission accomplished!
Reactions: Thomas B
samydraria
