Were is my white balance setting ?
Coco 60
Montreal Canada
Today i was flying my MM and couldn't find the adjustment setting for the manual WB ! Went into the Three dot menu and selected manual WB, but doesn't show on my ipad screen ! What am i doing wrong.. anyone
After the 3 dot menu, go to top tabs, select "camera", then come down and select "advanced settings", then you will see either manual or auto white balance. If you select "manual" tab, then you'll be able to use the slider to change.
Reactions: fificap
Captain Netflix
