- Joined
- Oct 20, 2017
- Messages
- 503
- Reactions
- 146
- Age
- 28
I wish DJI provided a way to put the Mavic into ATTI mode, as with the Phantoms, so one could practice flying with it enabled.. Forcing ATTI mode requires directly editing parameters, and may be something an operator should consider learning before attempting dangerous flight operations.
They did, but it seems the pinheads in the policy dept didn't call for the option to be built into the GO app. You can control the modes of the 'sport' switch using a parameter change using the Assistant software running in developer mode. More info can be found here: howto:parameterhacks [dji.retroroms.info]I wish DJI provided a way to put the Mavic into ATTI mode, as with the Phantoms, so one could practice flying with it enabled.
Thank you. Great info.They did; More info can be howto:parameterhacks [dji.retroroms.info]
But it doesn't matter if you have your sensors on or not. If you lose connection you are ******Turn off your sensor while fling under bridge short bridge Usualy not issue
Long dark bridges...NO BEUNO
Will the RTH function kick in and the drone just fly up and smack the bottom of the bridge since it doesn't have any sensors on the top? Is it a good idea to keep RTH altitude lower than the bridge itself in case this happens?
Haha I had the same question when I was planning a flight under a bridge over a river.
What I did is to set the RTH to "Hover" rather than "Rertun to Home", for exactly the same reasons:
In the area where I was filming, I was able to get quite close to the location of the bridge, so I figured if the connection would get lost, I would make my way to the bridge, hope for re-connection and fly the Mav out of there, rather than have it ascend and crash into the underside of the bridge, then falling into the river...
Oh ****. This was the answer I was looking for lol. Didn't even realize you could do that. Just for curiosity's sake... What if you weren't close to the bridge? Would it hover until the battery died or is their another setting where it will only hover and then RTH once the battery reaches a certain %?
