DJI Mini 2 vs DJI Air 2S which would you buy and why? Pro's and con's Would you do it differently if you could?
It really depends on your needs. Everyone needs something different. If you just want a drone to fly every now and then with decent-quality pictures, the Mini 2 is for you. If you want a professional quality drone and plan to fly more often or in more challenging conditions requiring greater stability and speed, then I'd go with the Air 2S. I've had both and I must say, I much prefer the Air 2S. But, as I said, it's all about your needs. The Air 2S suits me better, but for someone else, they might prefer a Mini 2.DJI Mini 2 vs DJI Air 2S which would you buy and why? Pro's and con's Would you do it differently if you could?
It depends. The Mini 2 doesn't need to be registered (because it's less than 250 grams) but the Air 2S does. However, that's only a $5 disadvantage and you can use the registration number on all drones. In my opinion, the size is an advantage because while bigger, it's still easily portable. They say the Mini 2 can fit in your pocket which is supposed to be an advantage but you forget about your phone, the controller, and possibly extra batteries. Unless you have super big pockets, you're going to need some type of case anyway. Therefore, I'd say you might as well get an Air 2S.I was thinking that the sensors would be a big plus! But would the size be an advantage or disadvantage?
Very discussed post - so searching is a good thing to find past threads or even at the bottom of this thread are "Similar Posts."DJI Mini 2 vs DJI Air 2S which would you buy and why? Pro's and con's Would you do it differently if you could?
