whats it mean rth please check on the map when starting up dji go 4app
It means that your position is recorded in memory if and when you push the button RTH (return to home) so the drone will fly back to where you started from regarding to the GPS position.
Yes downloaded full manual this is very helpful got lots of info can read this with out magnifier to see thanks again
Besides right location on the map, ensure right orientation of your drone direction on the map.
This is where most flyaways can occur when orientation on the ground doesn’t match how it appears on the map.
For precision landing to be set, you then need to take the Mavic straight up ~ 10m and get that screen notification.
Precision landing is optional though, you can fly ok without that set, but it’s nice for RTH almost landing on the exact spot and orientation it took off from.
keem21
