What's up fellow pilots. Coming to you from Compton, Cali
Hello from the Crossroads of America dreyezjr.
Nice to meet you David. 🤝
If you haven't done it yet, take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
And depending on what you are flying, it may need to be registered with the FAA.
Here's an app that will help to determine the airspace around you and may be able to get permission if you live near airports or other restricted areas.
Good luck, have fun, and welcome to the Forum. :cool:
Thank you for the info. Already got my trust. working on my 107 as we speak.
Reactions: MA2 317 and Cafguy
I'm new to the drone world.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
I read you have your TRUST and are working on your 107… I do not know if you have a drone yet but remember, once you get one as a rec pilot, if it weights more than 250 grams, it has to be registered. Once you get your 107 and you use that drone, no matter how little it weighs, all drones must be registered if used under your 107 license in a commercial enterprise…
Since you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome to the forum! :)
Thank you so very much for all the wonderful info.Time to get to reading.
Reactions: LoudThunder
Heraklit0469
