They need to be replaced when they are visibly damaged.how do i tell when i need to replace my props?
That depends on how often you damage your props. If you're careful, a set of props can easily last years.how often should i replace them?
its all relative if you are a commercial pilot then it makes sense to have a prop change interval written into your flight manual,but it does not mean that the props were worn out ,you could put on a brand new set and damage them on the first flight,the most important aspect is regular preflight checks looking for damageAfter watching my friends phantom 4 pro fall out of the sky at 30 feet while it was hovering for 3 minutes, due to a broken prop, I started to do some research.
Drone U amongst others recommends prop replacement every 20 hours of flight time.
That's dangerous advice. A set of props could become damaged after just one hour of use.Drone U amongst others recommends prop replacement every 20 hours of flight time
