WHICH IS BETTER FCC OR CE? I live in India and India follows FCC OR CE Mode.?
FCC 100% better, CE power output is far less, simple as that, forget range, interference and urban enviroment works much better with FCC mode every time, I live in UK and CE power levels suck big time.
Reactions: prathamesh_dji
Have the restrictions, in India, on under 250g drones been removed?
If not will FCC vs CE be really relevant? From memory there was a ridiculously low ceiling which will probably limit range anyway.
By the way, be aware the FCC and CE versions of the drone and the controller ARE NOT interchangeable, so you will always have to use a CE drone with a CE controller etc..
As someone else said, if you have a choice to go with FCC, it is a no brainer to go with that one.
Hey there
I have mavic mini FCC version there are 5 channels showing in transmission tab
I enabled FCC hack on RC following this YouTube steps
How do i know that FCC hac is enabled or not ??
After this hack i had only 5 channels showing in transmission tab. And previously it was 5 only
Reactions: boabdil
nikt_elo
