Which motor RPM
dronelover1234
Hi,
We are servicing our mavics and have seen that some companies check this - Checks to ensure motors operate at the correct RPMs and are able to select required speed quickly. Would anyone know what the correct range of motor RPMs is?
This may be more of a long shot, but how quickly is the motor meant to accelerate?
Thanks
i think it means that all the motors are spinning at the same speed and are not impeded in any way you would need some form of optical measuring equipment to verify this the IMU along with the speed controllers constantly change the speed of the props to keep the drone stable so it would need to be done at idle before take off when in theory all the props should be at the same speed
1Burleyman
