why does this happen?
Is this your SD card footage or cache on device ?
As it happened when you turned, your antenna might have just hit something bad I think, but connection issue could have caused bad record feed if it was the cache recording shown above.
Does it do this in other locations ?
It looks like strong interference to me, possibly wifi or magnetic / power lines etc.
If it does it every location, including well away from homes or anything like electricity transmission lines and metal objects, it could be a an issue with the camera or other on board part that affects recording to card.
Reactions: TooTall
SD card write rate could be too low.... (I'd say the card should be rated at least 60 MBit/s; there's a recommendation list on DJI website)
Richd54
