Why so complicated filenames for images and videos?
The file naming scheme is "DJI_0000.file_extension" where the 0000 is a sequential four digit number starting with 0001 and ending with 0999. Once it reaches the later, it resets and starts again at 0001. I don't see what is complicated about that. Now, if you are asking why it stops at 0999 instead of 9999; that is a valid question :)
Reactions: Lionfish
The more complicated the name, the less likely there will be a duplicate somewhere on your network.
and I believe there is a setting to continue the numbers so it doesn't reset each flight.
To clarify my question, I took 2 images and 1 video, after formatting the SD cards of both M2P and Smart Controller.
Here are the directory listings:
On the SD card of the M2P: folder DCIM\100MEDIA:
Date Hour Size Filename
05/05/20 13:45 796,107,069 DJI_0010.MP4
05/05/20 13:52 14,326,641 DJI_0011.JPG
05/05/20 13:52 13,112,188 DJI_0012.JPG
On the SD card of the Controller:
Folder DJI\dji.go.v4\CACHE_IMAGE:
05/05/20 14:50 16,482 thumb_4019566441cb5f5c_1588679128000.jpg
05/05/20 14:52 21,818 thumb_566d009175bc3d6d_1588679554000.jpg
05/05/20 14:52 21,334 thumb_f5151e26ab3282df_1588679566000.jpg
Folder DJI\dji.go.v4\DJI Album:
05/05/20 15:03 779 org_4019566441cb5f5c_1588679128000.info
05/05/20 15:03 796,107,069 org_4019566441cb5f5c_1588679128000.mp4
05/05/20 15:03 329 org_4019566441cb5f5c_1588679128000.org
05/05/20 14:52 14,326,641 org_566d009175bc3d6d_1588679554000.jpg
05/05/20 14:52 13,112,188 org_f5151e26ab3282df_1588679566000.jpg
Clearly I have the recorded files (same filesize) on my SC, but with what I call complicated filenames.
What kind of filenames do you have on your controller?
Reactions: Lionfish
OK, got you now. The files on the SC are the cached versions of what is recorded on the SD card in the AC. As such they are quite unimportant (they are also very likely very low res versions of what is recorded on the memory card in the AC).
Look for a setting to stop saving the cache files ... unless you can think of a reason to hang on to with low-res thumbnails.
Reactions: Lionfish
Please notice that the files on the AC and on the SC (...\DJI Album) have exactly the same sizes (look at the size after the date and hour in my directory printouts). The SC directory ...\CACHE_IMAGES contains (very small) thumbnails, including one for the video.
Reactions: Lionfish
Huey0315
