Why would the remote have a higher minimum operating temperature than the AC?
Characteristics of the battery that is being used. Or the components within the Remote Controller have specifications that have a minimum temperature at which they will function properly.
Reactions: Former Member
One would think it would be the other way around. At 14°f, the aircraft is sucking freezing cold air in through the intake. The thing to remember here is that the M2's fan only comes on at a very low speed when you power it on. It's just enough to cool the components. The core board gets so hot so quickly that the factory must have determined it will counter any temperatures above 0°f.
The controller is another story. It has a display. Not sure if displays freeze up, but Im sure it's no a coincidence that 32° is freezing and thats what the controller is rated for. Thats my thought as to why it's not able to tolerate the cold better than the drone.
Just another thought. If you are flying in the freezing cold, remember that your device might not work very well below freezing. The drone will be the least of your problems if your display goes out. A member had posted a controller glove up here today, and that might help keep your device and controller safe when the temps drop, plus it will keep your hands warm.
Here's What the Cold Can Do to Your Phone or Tablet | The Weather Channel
Reactions: Prismatic
As has been said the battery in the Mavic will heat faster in use due to the significantly higher current draw.
Another issue might be related to the display performance- a lot of LCD's don't function properly below 0 degC.
Yeah, I think the display is probably a big factor. I plan on snapping some sunrise pics later this morning. Temps are supposed to be 10 to 15 degrees, so we'll see what happens. I won't be out very long though.
Just another thought. If you are flying in the freezing cold, remember that your device might not work very well below freezing. The drone will be the least of your problems if your display goes out. ...
Yeah, been there, done that, got the heart attack. ?
You realize you responded to an 11 month old post?
You realize that winter is here, and moreover, the forum software suggested this as ”similar” to a thread started today, meaning further traffic is likely?
I’m not sure why you felt I should be advised of this anyway. It’s still relevant, and my personal experience underscores important information.
Recommend a new thread... just wanting to increase odds of responses. This could work, but the members who posted may not still visit the site, and the recommendations of the server are just a word/ phrase matching with years of history here.
Best of luck! ... and fly well.
merycs
