Will it fly?
Will it fly?
  • Yes, it will do fine
    Votes: 8 53.3%
  • Yes, but like a drunken bird
    Votes: 2 13.3%
  • Maybe...
    Votes: 2 13.3%
  • No
    Votes: 1 6.7%
  • The drone will die
    Votes: 1 6.7%
  • You are crazy!
    Votes: 3 20.0%
  • Total voters
    15
Photo-Sorko
Carinthia/Austria
Site
photo-sorko.at
Hello there!
That's the question. Since a few days I'm thinking about a way to film the Mavic itself during flight. From the Mavic. And the footage should be in equal quality. So, what to do? Grab a GoPro, an extension and a mount and put it on the Mavic. I don't know if it will fly but I'll test it tomorrow. What do you think?
Greetings
Jürgen
That's going to push the centre-of-gravity back on that bird! The rear prop's will be pushing like crazy to keep it level and that means you'll reduce their capability to manouvre and compensate for gusts etc. to keep stable ... Don't let it get too high above a very soft surface on your test flight!!!! Good luck ...
I agree. can you move the mount further front?
Reactions: Photo-Sorko
I'll try it in a safe environment for my drone. I love it.. her... she needs a name!
That would contradict my intentions but if it doesn't work in this way, that's the next I'll test.
Reactions: charliesRig
If the camera has the perspective you are looking for, which looks good, then just move the mount and not the camera. OR!!! counterbalance the weight of the camera with some weight in the nose! Try putting something that weighs around the same or less than the whole camera and arm at the tip of the nose.
If you put your fingers under the drone and try to balance it on the yellow line, you will see if you need to add weight to the front.
BTW, try to fly very slowly with this on there, it looks top heavy.
Hello there!
View attachment 66149 View attachment 66150
View attachment 66151 View attachment 66152
Greetings
Jürgen
Oooh, it looks like a scorpion! (g)
Is that curved metal an official adapter of some sort or your own contraption?
Putting some more thought in it, maybe, I'll try to run the GoPro without the battery and use a very small power bank, mounted just behind the gimbal on the bottom of the drone. That will reduce the allover weight an center the mass. But first it must fly, before I throw more money and engineering on it. If all works out, I'll provide you with all information that you can build a professional GoPro-films-your-own-drone-mount. :)
For sure. I'll start with hovering in ~1m and than slowly fly forward, backward, sideways and change direction. Only if I'm sure, it will not harm the drone, I'll go on. I also have to fix the end of the straps so that they cannot get into the props.
That's.... true. :D
It's this thing:
POV Extender
It's very lightweight and stable and has little surface... how do you say in English? I mean the it has a very small aerodynamic effect. In German we say "Angriffsfläche" (surface of attack - 1:1 translated). Dictionary says "sail surface".
Greetings Jürgen
It can handle the load but the pendulum effect might play havoc with control.
And here is.... my drunken bird!
As you can see, it does fly. But as @JAW said correctly the pendulum effect has negative effects to the automatic stabilization. If I can mount the GoPro more tight, it would be a little better. The video already shows my second attempt. In the first, the GoPro was to loose and it started swinging right after the take off.
The center of mass was off by about 15mm. This and the additional weight was handled without effort from the drone.
I've to think about my next steps. :)
Greetings
Jürgen
drone selfie
That's.... true. :D
It's this thing:
POV Extender
Greetings Jürgen
Hallo Jurgen,
Du meinst "minimal surface area" so im vehrwenden, there is very low aerodynamic resistance due to the shape or thickness of the arm. Du kannst auch sagen, es hat ein "low drag coefficient".
You could also add weight to the opposite two arms, to off set the weight that the camera and arm have added out the back. Then the only thing to affect flight would be the aerodynamic drag of the camera and arm, with the camera being the most, from what I see.
However, that is still minimal because you are not here to create a racing machine, but rather, to just see the drone in flight, or a portion of the drone in flight and that should not really present much of a problem. Though I would suggest you get the weight and balance (CG) sorted out, before flying, to make it fly the best.
Greetings
Jürgen
After looking at your video, I think you can still get the front section of the drone in the filming frame and get the effect you want during flight and get a better forward looking perspective, if you shorten the arm, lowering the camera, then of course changing the angle of the camera from a less downward view to a more forward view.
By lowering, shortening the arm, you will get less pendulum effect as the drone moves about and then get a better overall image with smoother flight. I'd say you could get away with maybe half the length you have in that video. Try that and see how it looks, feels and films, before giving up completely. Most of that swinging movement is caused by the out of CG of the drone, so be sure to compensate with added weight if and when you shorten the arm.
ironwingstudios
