Wipkviey Wing 12
Loakley
UK
I'm new to drone flying . I have a Wipkviey Wing 12 as a starter unit. A present for Christmas. I'm getting on with the flying part quite well, however. How do you save videos and photos please? The instructions are great as they are a literal translation from Chinese. Thanks
Hello from the Crossroads of America Loakley.
This site is basically for DJI Mavic drones but somebody may have a WW 12 aircraft and can assist you.
Good luck and welcome to the Forum. :cool:
if you scroll down to the bottom of the page ,you will see a list of the different sites ,choose the one that says Drone Pilots in blue, on the bottom line, and that may have info ,on the type of drone you have
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
I would suggest if your user manual, (Yeah, if you have one, it pays to read it…), if you do not have a user manual, you need to go to YouTube and watch a bunch of videos…
If one of the members has experience with your drone, a video showing you the How-to takes a lot less time to digest…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Hi - I have exactly the same issue with my Wing 12, have you had any success resolving it? I’m using an iPhone 12 and TYH Fly app. I’m a novice but will be very disappointed if I can’t record pics or vids.
Doug
  • Wow
Reactions: LoudThunder
There are several videos on YouTube about the Wing 12, perhaps they might hellp...
Reactions: wjkrysak
Thanks. I have watched these but they provide little insight into the issue - in fact they confuse further - in one the operator talks about using a third party camera (GoPro type) but there is no way of attaching it to the wing 12 and even if there was I reckon that it would be way overloaded and if it did manage to get airborn would be seriously out of balance.
  • Wow
jhgfdhjrye
